Зарубежные видеоклипы 90-2000-х, Иностранные группы и исполнители (страница 83) |
14.4.2016, 12:02
#1643
Пользователь №: 3489
Благодарностей: 656
INKA ( Inna Oliynyk, ukr: Інна Олійник) is a ukrainian singer and songwriter. INKA - I Don't Wanna Know (2009) [16:9]File Name: INKA - I Don't Wanna Know (2009).VOB File Size: 104.5 MB / 109 576 192 bytes Duration: 00:03:16 Resolution and Framerate: 1024x576, 3 835 Kbps, PAL Format: MPEG-PS Audio: AC-3 (AC3), 448 Kbps (CBR), 48.0 KHz, 2 channels, 1 stream pass: INKA-IDontWannaKnow-byVit
Сообщение отредактировал easyrider - 21.9.2016, 13:00
18.4.2016, 1:56
#1651
Благодарностей: 3958
Mode One - Get The Chance (Extended Version) [2016]File Name: Mode One - Get The Chance (Extended Version) [2016].mp4 Size: 89735139 bytes (85,58 MiB), duration: 00:06:41, avg.bitrate: 1790 kb/s Audio: aac, 44100 Hz, 2 channels, s16, 125 kb/s (und) Video: h264, yuv420p, 1280x720, 1656 kb/s, 29,97 fps® (und)Код
21.4.2016, 18:52
#1655
Благодарностей: 656
Imperio - Veni Vidi Vici (1994) [NTSC, 6 ch, clean]File Name: Imperio - Veni Vidi Vici (1994).VOB File Size: 218.99 MB / 229 627 904 bytes Duration: 00:04:02 Resolution and Framerate: 720x480, 6 829 Kbps, NTSC Format: MPEG-PS Audio: AC-3 (AC3), 6 channels, 448 Kbps (CBR), 48.0 KHz, 1 stream pass: IMp3RIO94VnVdVc-byVitImperio - Nostra Culpa (1995) [NTSC, 6 ch, clean]File Name : Imperio - Nostra Culpa (1995).VOB File Size : 169.24 MB / 177 465 344 bytes Resolution : 720x480 Duration : 00:04:08 Video : MPEG Video (MPEG-2 Video), 5 044 Kbps, 29.970 fps Audio : AC-3 (AC3), 6 channels, 448 Kbps (CBR), 48.0 KHz, 1 stream pass: IMp3RIO95NostraCulpa-byVit
Сообщение отредактировал easyrider - 19.9.2019, 2:23
24.4.2016, 15:37
#1656
C.C.Catch - Medley (Aniversary Megamix,RTL,die ultimative chartshow,16,09) [2006]File Name: C.C.Catch - Medley (Aniversary Megamix,RTL,die ultimative chartshow,16,09) [2006].vob Size: 127825920 bytes (121,90 MiB), duration: 00:02:45, avg.bitrate: 6198 kb/s Audio: ac3, 48000 Hz, stereo, s16, 256 kb/s Video: mpeg2video, yuv420p, 720x576, 6790 kb/s, 25,00 fpsКод
24.4.2016, 23:50
#1658
Благодарностей: 656
Imperio - Quo Vadis (1995) [NTSC, 6 ch, clean]File Name: Imperio - Quo Vadis (1995).VOB File Size: 164.24 MB / 172 220 416 bytes Duration: 00:03:56 Resolution and Framerate: 720x480, 5 148 Kbps, NTSC Format: MPEG-PS Audio: AC-3 (AC3), 6 channels, 448 Kbps (CBR), 48.0 KHz, 1 stream pass: IMp3RIO95QuoVadis-byVitImperio - Atlantis (1996) [PAL, PCM]File Name: Imperio - Atlantis (1996).VOB File Size: 303.54 MB / 318 285 828 bytes Duration: 00:03:54 Resolution and Framerate: 768x576, 8 903 Kbps, PAL Format: MPEG-PS Audio: PCM (PCM), 1 536 Kbps (CBR), 48.0 KHz, 2 channels, 1 stream pass: IMp3RIO96Atlantis-byVit
Сообщение отредактировал easyrider - 19.9.2019, 0:10
